I need help
so i just bought a new computer i can barely run battle field 4. anyone have any idea why?
 SPECS: FX-6300
POWERCOLOR R9 270X
AWM 600W POWER SUPPLY
A-DATE XPG RAM
With these specs i can only average 30 fps on high
How much system memory do you have ? and are you running a 64 bit operating system ?
it says 8192 MB ram windows 8.1 64 bit
i've seen a bunch of benchmarks on bf4 with r9 270x and saw people got 60+ on ultra?
I think I remember hearing somewhere that the game uses the cpu a lot more than most games, so maybe the benchmarks you have seen they have better cpu's ?
BF4 loves high speed memory. What speed is your memory running at?
4gb 1866
Recommended specs for the game are 8gb of ram. So that is one point in your system that will be giving you lower frame rates.
Are all of your drivers up to date ? Might be worth checking them.
im downloading the powercolor driver for my r9 right now to see if it helps
You're getting the drivers straight from AMD yeah?
http://support.amd.com/en-us/kb-articles/Pages/latest-catalyst-windows-beta.aspx
i tried downloading catalyst yesterday but it just got stuck when downloading and didnt want to finish
do you use ghostery? i know that sometimes gives problems with downloads/updates.
