I need help!
Hey guys, I am in a real state of despair.
I will start off by saying I am only 15 years old, just making that clear. I want to get a Built Desktop for around £500. I know and as you all know, this is good to play most games (Maybe not on Max Graphics), and it can be upgraded over time as I accumulate money to spend on it.
With my Birthday at the end of this month, I went up to my dad today and told him I didn't want a laptop, I wanted money in order to purchase a desktop. He started going on about desktops being old fashioned and how nobody uses them any more. I finally get the chance to tell him about how the value-for-money is so different, telling him how an £800 laptop could be bought for £300 as a PC (Maybe a tiny lie). Then he gave me an option. If I put £300 in, my parents will put £500 to get a better laptop. I am still really on edge about this, and I know everyone on this site is super bias towards building PC, but try and list advantages as opposed to raging. So, would it be at all a good idea to accept said offer?
Also, if he is super reluctant about even letting me get a desktop, how would I convince him to allow me to build my own with no experience? Is there any way to customise a laptop? I don't think so, but if there is a would be happy if you would let me know.
Sorry if this is in the wrong section, but think about your answers because this is a damn big deal to me, I have only had one computer before that is this crap I'm writing on now. It's under £500 laptop, runs Just Cause 2 at under 20fps with minimum everything and cannot even run Chivalry: Medieval Warfare without crashing. My laptop is also 3 years old.
Additional Details Added.
My father had the same thinking.  We used to have desktops when I was young(I'm 17 now, not too much older), and around 2001 we switched over to laptops and my dad always swore by laptops since then.  Last year I bought a used desktop to see what I could get for my money(sold it later for a newer tech build).  Now that I have actually bought and built a desktop, I can say that for mid-high end gaming, a desktop really is the way to go.  Before my desktop(s), my family had 1 laptop, which was running on a old i5-2410m, which had a (terrible by today's standards) Intel HD 3000 graphics.  It can barely run Minecraft, and TF2 lags to no end.  With laptops, you pay for branding, battery, lots more engineering, compactness, and portability.  Desktops are much better performers at the ~$500+ range than laptops.  So I'll help you a bit as a £500 can get you a pretty decent rig to game at 1080p.
Since your family has laptops, I'm going to assume you need a keyboard and monitor.  With a somewhat low budget though, I would suggest getting Windows 7 from a friend, or online(If you know what I mean).  You can also reformat your laptop's hard drive and use it in this build to save some money.
So here goes my build suggestion(slightly over your budget with HDD :/ sorry):
http://uk.pcpartpicker.com/p/21ZTq
CPU: AMD FX-4300 3.8GHz Quad-Core Processor.  This should pull you through most games.  If you have the budget, an FX-6300 would be my optimal suggestion.  Most games don't require super strong CPUs, and these should perform pretty well for the budget.
MoBo: Asus M5A97 R2.0 ATX AM3+ Motherboard.  This motherboard has some cooling on the VRMs, which are important, as noone likes having their motherboard get burned out.  I would recommend this motherboard for CPUs up to AMD's 6 core ones.
RAM: GeIL Enhance CORSA 8GB (2 x 4GB) DDR3-1600 Memory.  8 gigs is around the sweet spot for gaming.  You rarely get above 6 GB of usage during gaming.  I would go with the cheaper PNY one with no heatsink, as heatsinks are usually more bling than for performance, but they're currently out of stock on amazon and might not ship for a month or two.
HDD: Seagate Barracuda 500GB 3.5" 7200RPM Internal Hard Drive.  Cheap hard drive from a reliable brand.  It's quite likely that your laptop has a little openable door thing on the bottom, where you can swap hard drives.  If you're not going to be using your laptop anymore, I would take out the drive, re-format it, and put stock windows onto it.  You can save 35 pounds by doing this.
GPU: XFX Radeon HD 7850 2GB Video Card.  These are pretty damn good for their price point.  2 gigabytes of video RAM will be fine for a bit, especially at resolutions of around 1080.  I has a 1GB HD 7850 and was able to play a lot of the games on high-ultra settings(TF2, Minecraft, Bioshock Infinite).  The 2GB of RAM in the card I picked for you should perform better in the long run.
CASE: Cooler Master K280 ATX Mid Tower Case.  Cheap and should fit all components.
PSU: XFX ProSeries 450W 80+ Bronze Certified ATX Power Supply.  This line of PSUs is both inexpensive and based on a Seasonic design.  Seasonic has been in the power supply market for quite some time now and they make some of the best PSUs.  I have the 550w version in my own system and it works great.
ODD: Samsung SH-224DB/BEBE DVD/CD Writer.  If you need this, that is.  You can install windows from a 8GB flash drive if you have one.  If you don't just make a bootable DvD and install this into your computer.
Monitor: Hannspree HL229DPB 21.5" Monitor.  Cheap 1080p display.  Still ate up a lot of your budget, though.
KB/Mouse: Gigabyte GK-KM6150 Wired Standard Keyboard w/Optical Mouse.  It was the cheapest keyboard available that I could find.  It happened to come with a mouse.
This should be able to allow you to push at least medium on the latest games, and quite often max them out.
Here is a free primer on tech jargon:
PC: this simply means personal computer. If it is a computer (typically identified nowadays by possessing a keyboard, mouse, and an operating system, then it is a computer. By this aging definition, modern smartphones are computers. Go figure.) Even Macs are actually PCs. Laptops are PCs. Desktops are also PCs.
Laptop: most modern laptops aren't really laptops. Although the title "notebook" seems archaic, it is a more apt description of a device whose cooling solution was not actually designed for you to set it on your lap. These are portable computing devices with batteries that allow them to function for a period of time while unplugged. These feature a screen that is mounted on a hinge to a central processing unit that traditionally features an attached keyboard. There are some notebook computers that have switched from a standard button keyboard to a touch-screen, thus effectively having two screens. The term laptop evolved out of the tendency for people to use these portable computing solutions while seated, cradling them on their laps. Originally, notebook computers derived their name from the way that they folded closed like a paper notebook.
More information about the analysis of the relevancy of notebook computers and desktop computers:
Modern notebook computers use low-voltage, portable components, and as such are extremely powerful for the amount of energy that they consume. For everyday computing, a notebook with a relatively speedy processor is actually to your benefit, because it offers you the capacity to move about and take said computing device with you on a whim.
However, one has to realize that the primary reason why desktop computers (including such offerings as nettops and thin-clients) are significantly more powerful than their notebook brethren is because they can typically be made with larger dies and more robust power requirements. A typical notebook will draw only between 35 and 100 watts from the mains when it is plugged in, a desktop computer typically will draw between 250 and 1200 watts, depending on the power requirements of the components within, and the energy efficiency rating of the power supply. Due to the significantly more robust component variety, it is highly unlikely that desktop computers will become passé anytime soon, the amount of computing power that you can get for the money spent is considerable, however, portable computing devices are growing more and more powerful with each successive generation. I predict that in the future, possibly as soon as 15-20 years from now, desktop computers may go the way of the dodo, and laptops or some other form of portable computing will take over in their stead. It may be for any number of reasons, we may have finally figured out quantum computing and are able to far exceed the demands of the software that we are able to make, thus reaching a computing golden age, or it may just be that large conglomerates like Microsoft, Google and Apple have created cloud-based computing systems that are so effective that it makes viable pecuniary sense to pay for their thin-client like devices and a service with which to interface with their server-farms. But for now, Desktop computers still have a place within the home of any dedicated gamer.
I would think the simple fact of a desktop lasting for years down the road would be a convincing reason with the ease to upgrade parts at the fraction of the cost of having to buy a new laptop. and you could always go with a SFF build.
plus laptops have heat issues and etc, I have yet to see one that doesn't. quite frankly you cant even use a "laptop" on your lap anyway, should really be called something else to begin with. number 1 cause I have seen of laptop death is overheating.
See my comment above ^. Hence the term notebook computer.
lol
Everyone I know calls them laptops anyway.  And I have had some friends who've come to me to help fix their "laptops" that overheated sitting on their bed...
Yeah, the pure upgradeability and performance potential is infinitely better than a laptop.  If you need something portable (e.g. college notetaking), then a lappy is needed.
