I need help with the ppsspp emulator
I'm an idiot and thus can't figure out how to transfer my final fantasy dissidia save with over a hundred hours into it to the linux version of ppsspp. Any help would be appreciated.
copy/paste the memstick folder from windows to linux. usbs are kewl.
oh yea, from the site http://www.ppsspp.org/faq.html
"My save states won't load!
Save states are tricky in an emulator that's not fully completed yet, as we haven't found all the state we need to save. Before 0.9.5, we would just copy all the state straight to an unstructured file. As the amount of state differed between the versions, no two were really compatible. From 0.9.5 and forwards, we have created a structured format where we can add new sections as needed.
So currently it's like this:
States from versions before 0.9.5 will never load in a later version
States from 0.9.5 and onwards WILL (in most cases) load in future versions!
That means that your 0.9.1 save states is stuck on 0.9.1, unfortunately. Use real saves to work around that."
I should have specified that I cant find the memstick folder in linux
i dont think it matters. you need the windows copy in linux so why does the linux copy matter?
I do have it running perfectly in windows I just want to abandon windows.
I'll just backup the windows version and run it in a virtual machine and thank you for your help I was worried my problem was a little to esoteric.
