yeah you are correct i posted the wrong on here is the correct one
CORSAIR Vengeance Pro 32GB (4 x 8GB) 240-Pin DDR3 SDRAM DDR3 1600
(PC3 12800) Desktop Memory Model CMY32GX3M4A1600C9 (Silver)
and this is the link http://www.newegg.com/Product/Product.aspx?Item=N82E16820233547&cm_re=32GB_%284_x_8GB%29_vengance-_-20-233-547-_-Product
Actually the case in the video is Define XL, but R4 will do the job as well, yeah... If you ask me, i would still say go with another case, but whatever.
The HyperX Beast is compatible with third-generation Intel Core i5 and i7 processors
JEDEC standard 1.5V (1.425V - 1.575V) Power Supply
VDDQ = 1.5V (1.425V - 1.575V)
667MHz fCK for 1333Mb/sec/pin
8 independent internal bank
Programmable CAS Latency: 9, 8, 7, 6
Posted CAS
Programmable Additive Latency: 0, CL - 2, or CL - 1 clock
Programmable CAS Write Latency(CWL) = 7 (DDR3-1333)
8-bit pre-fetch
Burst Length: 8 (Interleave without any limit, sequential with starting address "000" only), 4 with tCCD = 4 which
does not allow seamless read or write [either on the fly using A12 or MRS]
but the vengeance
DDR3 1600 (PC3 12800)Cas Latency9Timing9-9-9-24Voltage1.5V
Built for overclocking:
so what your saying is that best for performance ram is HyperX Beast, no doubt, but is it's about saving money i should go with
G.SKILL Ripjaws Z Series 32GB (4 x 8GB) 240-Pin DDR3 SDRAM
DDR3 2133 (PC3 17000) Desktop Memory Model F3-2133C10Q-32GZM
or
G.SKILL Ripjaws X Series 32GB (4 x 8GB) 240-Pin DDR3 SDRAM
DDR3 1600 (PC3 12800) Desktop Memory Model F3-1600C9Q-32GXM
or
Crucial Ballistix Sport 32GB (4 x 8GB) 240-Pin DDR3 SDRAM
DDR3 1600 (PC3 12800) Desktop Memory Model BLS4KIT8G3D1609DS1S00
where all three are good but no where near as good and reliable as the hyperX beast but way better than the vengeance .... is that correct
No. I am saying, that if your goal is to save money, you can go with the crucial and have the same performance. You can go even cheaper and still lose almost nothing. You can go with the Ripjaws Z for the higher frequency. My point is you have a choice... If i was to choose between the corsair and the beast i would have taken the beast. If i have to choose between all those models, however, i will take the 2133 Ripjaws Z, because it's high frequency with fairly tight timings of C10... And Gskill is quality brand.
my goal isn't saving money but rather performance, stability and longevity
so should that be G.SKILL Ripjaws Z Series 32GB (4 x 8GB) 240-Pin DDR3 SDRAM DDR3 2133 and will the live long and prosper i mean i know that the hayperx bests don't fail are the G.SKILL Ripjaws Z just as reliable
