Hey Guys Im sorry if this has been asked before but im really stuck and im not really experianced knowing its my first build.
For starters i really im on a tight budget (and hardware prices deffer here in saudi arabia) never the less here are the parts i was thinking of Bulding:
1- CPU: AMD FX-6300 FX-Series Six-Core Processor Edition, Black AM3 FD6300WMHKBOX
2- GPU: Gigabyte AMD Radeon HD 7750 2GB DDR3 2x DVI-D/HDMI/D-SUB PCI-Express 3.0 Graphics Card GV-R775OC-2GI
3- MotherBoard : Gigabyte GA-F2A85XM-D3H AMD Socket FM2 A85X (Hudson D4) HDMI SATA 6Gb/s USB 3.0 Micro ATX Motherboard
4- Hdd : WB Blue 500GB
5- PSU : Here is where im stuck Ive read that the CPU and the GPU that i Have choosen demand alot of wattage 500w And more but i have no idea what to get i found a 600w PSU but i Dont belive it would out that much power
6- Ram: sutck again for some reason Rams recently spiked in prices but im thinking a G.Skills Ripjaw x DDR3 2 4 GB sticks will do but at 72$ seems abit steep
IF you Guys could lend a helping hand to recovering Console gamer id be thankful
Ok your cpu whont fit on a FM2 Motherboard
Ram is going up and will continue to rise as DDR3 is being fazed out for DDR4
The video card is a bit low for gameing
What budget and what site can you order parts from in saudi arabia?
cooperman Thanks alot for the help and thats why i need help almost got useless mobo my budget is about 600$
ragingh4vok Amazon works Great i can order the parts but ill get riped of on the shipments around 16 bucks extra on each part which will total out around 80$ extra which i can use for higher-end Hardware
Sadly enough i really like the FX6300 but Im steering away Because its pretty hard to find AMD compatable parts here in the land of sand
I cant find ragingh4vok Amazon online but these parts will work well together
http://pcpartpicker.com/p/RWiB
http://pcpartpicker.com/p/RWmc
thanks alot cooperman so the 7750 2gb ddr3 is a no no ? because i found a great deal on one if its not up to todays standards i might have to scrap the build and start over
The 7750 is a lowend card you can only realy play well on 720p with it now cards have ddr5 ram (2gbs of ddr3 ram is never going to be used on that low a card anless you use 2 of them in crossfire)
