I need help with my build. $2000 budget
Im getting a new gaming computer soon and is this build any good?
I also want to do some basic editing and able to record gameplay with fraps at 60fps (1280 x 720p and on max for all games)
Heres the build.
- I am australian so things are in $AU and are bought from this site ( http://www.PLE.com.au)
 GPU: Gigabyte GTX680 OC 2Gb D5 - 574$ - Card from http://www.netplus.com.au
 CPU: Intel Core i7 3820 Sandy Bridge-E 3.6GHz 10MB - 299$
 RAM: 16Gb DDR3 G.Skill 4X4Gb 2133Mh = 200$
 MAWDERBOARD: Asus P9X79 LE LGA2011 ATX Motherboard - 250$
 AFTERMARKET COOLER: CoolerMaster Hyper 212 Evo CPU - 39$
CASE: CoolerMaster CM Storm Stryker - 200$ OR
NZXT Phantom 410 White Gaming Case - $145
 SSD: Corsair Neutron 120GB 2.5" SSD SATA3 555/211 - 139$
 HARDRIVE: Western Digital Caviar Green WD20EARX 3.5" 2TB 64MB Intellipower - 99$
 DISKDRIVE: Samsung 22X SATA DVD Writer - 18$
 POWERSUPPLY: ntec High Current Pro 850W 80PLUS Gold Semi-Modular - 219$
Over all this looks like a good build, there are just a couple of things I would change. 1 is the case, I recently bought an obsidian 650D and that thing is a beast, trust me you will not regret buying it. Other than that I would go for an i7 3770k not the 3820, this would mean getting a different mobo as well, I would suggest an asus sabertooth or an msi big bang mpower for mobo. I would also recomend checking out www.pccasegear.com they seem to have better prices, I live in Aus too and I've bought from pccasegear and can say that they are reliable.
Do what you want with the build and have fun building and gaming!
$2000? You can accomplish everything you want for much less, would you care if I made a build I thought that would be good for you but doesn't quite use your entire budget?
Sure! :)
