I need help to imrpve this build
I am making a mid grade pc for about £550
i play dota 2, bf3, far cry 3 blood dragon and sanctum 2..
CPU:AMD 8350: http://www.aria.co.uk/SuperSpecials/Other+products/AMD+%28Piledriver%29+FX-8350+4.00GHz+%284.20GHz+Turbo%29+Socket+AM3%2B+8-Core+Processor+-+Retail+?productId=52722
cooler: http://www.amazon.co.uk/Cooler-Master-Hyper-212-120mm/dp/B0068OI7T8
Asrock extrme4: http://www.amazon.co.uk/Asrock-Socket-970-Extreme4-Motherboard/dp/B0058HUQJ0
XFX Radeon R9 270X:  http://www.novatech.co.uk/products/components/amdradeongraphicscards/amdr9270xseries/r9-270x-cdbc.html
Corsair 8GB (2x4GB) DDR3 1600Mhz: http://www.dabs.com/products/corsair-8gb--2x4gb--ddr3-1600mhz-cl9-vengeance-black-performance-desktop-memory-kit-79V4.html?utm_source=awin&utm_medium=affiliates&utm_content=AW00&awc=3044_1382178974_f9958d3dcf7d7693581acb3e74214345
western digital 1tb blue: http://www.amazon.co.uk/1TB-SATA-lll-Desktop-Drive/dp/B00D0243DU
psu:http://www.amazon.co.uk/Corsair-Builder-Series-Modular-Certified/dp/B00ALYOTTI
Those components should be absolutely fine for the games you wish to play, what exactly did you need help with?
Looks alright, except the motherboard isn't the greatest match for that CPU.
Look for a board such as the Asus M5A97 Evo R2.0, Asus M5A99X Evo R2.0, or Asus M5A99FX Pro R2.0.  These have stronger power delivery systems and will be able to handle the CPU much, much better.
That motherboard is to weak for a 8350, get a 8320 and one of the mobos tech noob suggested :)
