I need help to build a gaming pc for £300
I need help to build a pc for around £300.I would like to be able to play games such a BF3 , ArmA 2 and DayZ.
I would like it to be able to have 4 fans and a mid case and leds if possible but this is ptional.Anyway please help and many thanks
Kim =)
http://uk.pcpartpicker.com/p/LCpd
Little over the budget, but this would be fine.
or this.
http://uk.pcpartpicker.com/p/LCra
This will be tough - you guys really seem to get it hard on pricing.
I would lean toward the Phenom II x4 build - if you can get a quad core then run with it.
An AMD APU build may also be a way to go... Xfire a 6670...
Asus M5A97 LE R2.0 Motherboard (AMD 970/SB950, DDR3, 6 x S-ATA 600, ATX, PCI-Express 2.0, USB 3.0, Socket AM3+)
£56.99
AMD HDZ965FBGMBOX Phenom II X4 965 - 3.4 Ghz AM3 Black Edition CPU, Retail Packaged
£75
Sharkoon T9 ATX Midi Tower Case - Green (pick your color)
£44.80
Sapphire 11201-17-20G AMD Radeon HD 7770 1GB GDDR5 GHZ Graphics Card (HDMI, DVI-I, Mini DisplayPort, PCI Express 3.0, 128-Bit, AMD CrossFireX Multi-GPU Technology)
£88.98
Crucial BLS4G3D1609DS1S00CEU Sport 4GB, Ballistix 240-pin DIMM, DDR3 PC3-12800 Memory Module(1600mhz)
£26.68
Corsair Builder Series CX 430 Watt ATX/EPS 80 PLUS Bronze Power Supply Unit
£38.94
Western Digital Caviar Blue 500GB SATAIII 6Gb/s 16MB Cache 3.5 inch Internal Hard Drive
£44.98
Total cost around £370 all pricing from http://www.amazon.co.uk/
Thanks how many fans does the case come with and how many can the motherboard support?
Sorry for the late reply. I dozed off for a bit.
The case will have 1 fan. I think.. Not really 100% on that.
The motherboard will support 3 fans including the cpu fan. Which is plenty because your gpu will have a fan and then your power supply will have fan. All kinds of air circulation would be happening.
If you feel a need for more, you can get fans that have a 4 pin peripheral connection.
Thanks i was going to build this and just keep on upgrading it
Great. Have fun with it!
Sorry one more question which would you say is better ?
I'd go with the AMD build because of the core count. In current games, both of those systems will perform roughly the same. The AMD will pull ahead in thread optimized games though.
Both rigs have great upgrade paths. You couldn't go wrong with either choice.
