I need help picking ram
Heys guys, i need some help picking ram because i really dont understand the specifics
I have two choices:
http://www.alientech.pt/product_info.php?cPath=180_28_67&products_id=25003
or this one
http://www.alientech.pt/product_info.php?cPath=180_28_67&products_id=6995
From my understanding CL9 should be better then CL10 but i dont understand that very well and i dont know why all the hyperx memory is more expensive then G-Skill, if someone can tell me which one should i choose i'd be very gratefull.
buy the cheapest from the reputible brands, it doesn't really matter at this point in time unless you are running something that requires super fast ram
I am running G Skill in my system, no issues running virtual machines/web browsing/battlefield 4/dota2 and whatever else i feel like doing with my pc
edit i have these ones
Personally I would go with the G.Skill because I have experiance with them and the Cas Latency is lower. On the other hand both are highly rated.
I'd recommend the G.Skill in this. If you just want the fastest you can get, maybe try the Crucial Ballistix Tactical? 1600mHz, CL 8
http://www.alientech.pt/product_info.php?manufacturers_id=37&products_id=24551
