I want to build a gaming PC but i dont know what parts i should put into it.I already have an intel i7 2.9Ghz processor, cooling fan, WLAN chip, and 6Gb RAM. So all i need are the missing parts for a fast gaming computer. I have $500 for the rest of the parts.
If u have any powerful builds that can run modern games at high fps and rendering i would appreciate it.
oh yeah, and you need to a motherboard that is compatible with that ram and cpu. The board in teh video is compatible with all sandybrige and ivybridge processors. Jow fast is your ram?
Anything below i7-2600 (talking about numbers here) is not based on the sandybridge architexture (which includes both sandybridge and ivybridge) the i7-2xxx is sandybridge, the i7-3xxx is ivy bridge. WITH AN EXPECTION, that being the "Sandy Bridge-E" family (I consider it a hybrid of sorts). I coundt find a list on intel's website, but i could find one on wikipedia, i know, it's wikipedia but anyway. http://en.wikipedia.org/wiki/List_of_Intel_Core_i7_microprocessors
You need to know what type of cpu you have, if it is an i7 940 you will need a 1366 mobo and if it is an i7 870 or 875k, you will need a 1156 motherboard. If you get a 1156 mobo, you will need to get some different ram.
I have an intel core i7 870 2.9 Ghz. The RAM is samsung, not sure but i am guessing it is 1600 Mhz. My friend had these in his PC and didnt want them anymore so i took them off of him. It is just the stock fan and i dont expect to do any overclocking for a long time.
So you need an LGA 1156 motherboard, if i recall correctly that means that the fastest memory supported is 1333hz. Being older, motherboards with a 1156 socket are cheaper.
also because it is 1156 it will need either 2 sticks of memory or 4 sticks, you could have one though it won't perform that great.
I suggest to look on ebay or somewhere like that to find an 1156 motherboard. try to buy a motherboard from one of the "bug three companies" MSI, GIGABYTE, and ASUS. I would not spend much more than one hundred dolars on a motherboard if you are not going to overclock.
for graphics I woud opt for either a radeon hd 7950 or a GTX 660ti. I would go for a 1tb western digital green drive, you may want to pick up some am as well, you can get 8 gigs for under 50 bucks nowadays so if you can, do.
