I need help on deciding on what kind of graphics card i should get and i want it to run high or medium on BF3, MW3, and Minecraft!! I would like for. The graphics card to cost at maximum of $130-135 US DOLLARS
Here are my PC SPECS I AM CURRENTLY BUILDING
CPU: AMD Phenom II X4 965 Black 3.4GHz Quad-Core Processor $100
uhh have you already purchased thoses parts? becase for $630 you can get a lot better, I also noticed that you didn't have a CPU cooler, so does that mean you don't intend on overclocking?
now yeah, the case is metro hokey as hell but the cold hard facts are that you have a monster in there that will perform greater than what the phenom build with only a $135 GPU could ever hope for
if you want to take out of the GPU budget or CPU budget which I don't recommend but you can get a better looking case (that's like 10-20 FPS drop for aestics)
You must remember that your graphics card has it's own cpu taking the "strain" off of your main cpu. However, the bus on your motherboard that handles the flow from your GPU can only handle so much depending on the motherboard. No point in putting a $600 graphics card in a $150 motherboard. You must consider how many monitors you intend to use as well. For that motherboard you won't need much more than something like a Saphire Radeon HD6870. 2xDVI, 1x HDMI, Displayport, HD and Blu-Ray compatible, dual slot dual fan active cooler. It is a 1 GB board GDDR 5
Well,i am kind of new to all of this stuff, i was a console gamer....but then i heard my friends saying to move on to the PC cause it gives you more choices and stuff..... I am a hardcore gamer...i just want a great gaming pc that will last for a long time under $700 US DOLLARS
