I need help installin windows 7 (bios problem)
I recently baught a msi am1 motherboard and an amd sempron 3850 and i upgraded because my old system so once i get my new parts i try installing windows and it saids it cant install because the hardware doesnt let it install on the hard drive and that i need to enable disk controller and it is enabled i need a way to fix this please help.
try changing the sata controller (in bios) from achi to compatibility mode. there are ways to enable it back after the install
ps.  if you have 2 hdd/ssd hooked up take one off and try in achi mode
