Hello there. I have been spending a couple of weeks trying to price out some second hand server gear to serve as a home server. In this time, I have found out many things about enterprise hardware that I had no idea about. A non-complete list of things I believe I have found out:
- Server cases are loud, because they don’t have to be quiet
- Server PSUs are loud, so you can’t even quiet down a server if it uses a proprietary PSU
- U.2 NVME ports are expensive, as far as I can tell. Looks like at least 100 dollars a slot if you’re using an oculink backplane
- I have no idea how server case backplanes are connected, and can’t seem to find much information on if you can use a, for instance, dell backplane on your own case.
- Epyc 7001 used equipment is like 4 times cheaper than 7002
- Intel naming conventions are confusing.
- It’s hard to find benchmarks for old hardware
- It’s find to find what motherboard to even use.
- Help, I’m in over my head.
Originally, I thought I was going to pick up something like a supermicro supersystem 4U and silence it, but that doesn’t look to be a thing that can even be done, thanks to the proprietary PSUs.
I started looking to a gigabyte motherboard with 7 PCI-E slots, but it looks like it’s impossible to even install anything in the board because the space overlaps with the ram slots.
What I want:
- As many PCIEx16 slots as possible on a motherboard. This way I can use them for NVME, or for old Tesla cards if I feel like spinning up some LLMs or something.
- 32 or more cores. Epyc7501 or a dual intel system maybe?
- Hot swap 2.5" bays if possible, so I can load it up with some raid 6 arrays
- Enough space to watercool the processors, and hopefully silence the whole thing
- I want to spend somewhere around 500 < x < 3000 dollars
What this will be for:
- Giant Expandable Storage Array
- Maybe running Pihole, and/or/ PFsense, or
- Run VMs to do things – maybe game servers, etc
- Serve up media
- Serve as a VPN into my network (when I figure out how to do that)
After a couple of weeks of looking, I’ve come to the conclusion of confusion. I’m looking for suggestions for parts, and answers to some questions such as:
- What all can you use occulink for?
- What’s the main difference between minSAS, Occulink, sas, sata?
- What sort of other weird enterprise connectors are there that I should know about?
- How are backplanes usually connected? And are they universal between systems?
- Where’s a good place to just search a database of hardware to find things that I might want?
- What other cool things should I do with a home server?
My background: I’ve built a lot of gaming PCs. I know consumer hardware pretty well, but it turns out I know like nothing about enterprise hardware. I know my way around linux, etc.
Thanks a ton if you got it this far. Thanks even more if you leave a comment.
[edit] The main resource I’ve been looking at for boards/cpus currently is Ebay. If there are other good resources out there, please let me know!
