[64554.276768] sd 7:0:0:0: Attached scsi generic sg2 type 0
[64554.278456] sd 7:0:0:0: [sdb] Spinning up disk...
[64555.280894] ..ready
[64556.286751] sd 7:0:0:0: [sdb] 1953525168 512-byte logical blocks: (1.00 TB/931 GiB)
[64556.287070] sd 7:0:0:0: [sdb] Write Protect is off
[64556.287072] sd 7:0:0:0: [sdb] Mode Sense: 43 00 00 00
[64556.287399] sd 7:0:0:0: [sdb] Write cache: enabled, read cache: enabled, doesn't support DPO or FUA
[64556.288760] scsi_io_completion: 16 callbacks suppressed
[64556.288764] sd 7:0:0:0: [sdb] FAILED Result: hostbyte=DID_OK driverbyte=DRIVER_SENSE
[64556.288766] sd 7:0:0:0: [sdb] Sense Key : Medium Error [current]
[64556.288768] sd 7:0:0:0: [sdb] Add. Sense: Unrecovered read error
[64556.288769] sd 7:0:0:0: [sdb] CDB:
[64556.288771] Read(10): 28 00 00 00 00 00 00 00 08 00
[64556.288776] blk_update_request: 16 callbacks suppressed
[64556.288777] blk_update_request: critical medium error, dev sdb, sector 0
[64556.288780] Buffer I/O error on dev sdb, logical block 0, async page read
[64556.289257] sd 7:0:0:0: [sdb] FAILED Result: hostbyte=DID_OK driverbyte=DRIVER_SENSE
[64556.289259] sd 7:0:0:0: [sdb] Sense Key : Medium Error [current]
[64556.289260] sd 7:0:0:0: [sdb] Add. Sense: Unrecovered read error
[64556.289261] sd 7:0:0:0: [sdb] CDB:
[64556.289262] Read(10): 28 00 00 00 00 00 00 00 08 00
[64556.289266] blk_update_request: critical medium error, dev sdb, sector 0
[64556.289268] Buffer I/O error on dev sdb, logical block 0, async page read
[64556.290369] sd 7:0:0:0: [sdb] FAILED Result: hostbyte=DID_OK driverbyte=DRIVER_SENSE
[64556.290372] sd 7:0:0:0: [sdb] Sense Key : Medium Error [current]
[64556.290373] sd 7:0:0:0: [sdb] Add. Sense: Unrecovered read error
[64556.290374] sd 7:0:0:0: [sdb] CDB:
[64556.290375] Read(10): 28 00 00 00 00 00 00 00 08 00
[64556.290380] blk_update_request: critical medium error, dev sdb, sector 0
[64556.290382] Buffer I/O error on dev sdb, logical block 0, async page read
[64556.290874] sd 7:0:0:0: [sdb] FAILED Result: hostbyte=DID_OK driverbyte=DRIVER_SENSE
[64556.290877] sd 7:0:0:0: [sdb] Sense Key : Medium Error [current]
[64556.290878] sd 7:0:0:0: [sdb] Add. Sense: Unrecovered read error
[64556.290879] sd 7:0:0:0: [sdb] CDB:
[64556.290880] Read(10): 28 00 00 00 00 00 00 00 08 00
[64556.290885] blk_update_request: critical medium error, dev sdb, sector 0
[64556.290886] Buffer I/O error on dev sdb, logical block 0, async page read
[64556.291348] sd 7:0:0:0: [sdb] FAILED Result: hostbyte=DID_OK driverbyte=DRIVER_SENSE
[64556.291349] sd 7:0:0:0: [sdb] Sense Key : Medium Error [current]
[64556.291351] sd 7:0:0:0: [sdb] Add. Sense: Unrecovered read error
[64556.291352] sd 7:0:0:0: [sdb] CDB:
[64556.291352] Read(10): 28 00 00 00 00 00 00 00 08 00
[64556.291356] blk_update_request: critical medium error, dev sdb, sector 0
[64556.291358] Buffer I/O error on dev sdb, logical block 0, async page read
[64556.291821] sd 7:0:0:0: [sdb] FAILED Result: hostbyte=DID_OK driverbyte=DRIVER_SENSE
[64556.291822] sd 7:0:0:0: [sdb] Sense Key : Medium Error [current]
[64556.291823] sd 7:0:0:0: [sdb] Add. Sense: Unrecovered read error
[64556.291824] sd 7:0:0:0: [sdb] CDB:
[64556.291825] Read(10): 28 00 00 00 00 00 00 00 08 00
[64556.291829] blk_update_request: critical medium error, dev sdb, sector 0
[64556.291830] Buffer I/O error on dev sdb, logical block 0, async page read
[64556.292291] sd 7:0:0:0: [sdb] FAILED Result: hostbyte=DID_OK driverbyte=DRIVER_SENSE
[64556.292293] sd 7:0:0:0: [sdb] Sense Key : Medium Error [current]
[64556.292294] sd 7:0:0:0: [sdb] Add. Sense: Unrecovered read error
[64556.292295] sd 7:0:0:0: [sdb] CDB:
[64556.292296] Read(10): 28 00 00 00 00 00 00 00 08 00
[64556.292300] blk_update_request: critical medium error, dev sdb, sector 0
[64556.292301] Buffer I/O error on dev sdb, logical block 0, async page read
[64556.292763] sd 7:0:0:0: [sdb] FAILED Result: hostbyte=DID_OK driverbyte=DRIVER_SENSE
[64556.292765] sd 7:0:0:0: [sdb] Sense Key : Medium Error [current]
[64556.292766] sd 7:0:0:0: [sdb] Add. Sense: Unrecovered read error
[64556.292767] sd 7:0:0:0: [sdb] CDB:
[64556.292768] Read(10): 28 00 00 00 00 00 00 00 08 00
[64556.292772] blk_update_request: critical medium error, dev sdb, sector 0
[64556.292773] Buffer I/O error on dev sdb, logical block 0, async page read
[64556.292778] ldm_validate_partition_table(): Disk read failed.
[64556.293240] sd 7:0:0:0: [sdb] FAILED Result: hostbyte=DID_OK driverbyte=DRIVER_SENSE
[64556.293241] sd 7:0:0:0: [sdb] Sense Key : Medium Error [current]
[64556.293242] sd 7:0:0:0: [sdb] Add. Sense: Unrecovered read error
[64556.293243] sd 7:0:0:0: [sdb] CDB:
[64556.293244] Read(10): 28 00 00 00 00 00 00 00 08 00
[64556.293248] blk_update_request: critical medium error, dev sdb, sector 0
[64556.293249] Buffer I/O error on dev sdb, logical block 0, async page read
[64556.293729] sd 7:0:0:0: [sdb] FAILED Result: hostbyte=DID_OK driverbyte=DRIVER_SENSE
[64556.293733] sd 7:0:0:0: [sdb] Sense Key : Medium Error [current]
[64556.293735] sd 7:0:0:0: [sdb] Add. Sense: Unrecovered read error
[64556.293737] sd 7:0:0:0: [sdb] CDB:
[64556.293738] Read(10): 28 00 00 00 00 00 00 00 08 00
[64556.293745] blk_update_request: critical medium error, dev sdb, sector 0
[64556.293747] Buffer I/O error on dev sdb, logical block 0, async page read
[64556.294713] Dev sdb: unable to read RDB block 0
[64556.297070] sdb: unable to read partition table
[64556.297870] sd 7:0:0:0: [sdb] Attached SCSI disk
Yeah I'm pretty sure that HDD is dead or dying.
There is nothing i can do to save the HDD?
Unfortunately I don't think so. RMA if possible.
