My monitor has been flickering white lines and black screens since an nvidia drivers update please help me fix it
Have you tried DDU and installing the previous driver version?
Do you know any stable driver version? I will change it to that
Also double check cables are still firmly attached both ends
I do not follow driver releases. And I doubt anyone does.
You said it started AFTER the driver update, so that implies the latest driver was installed. Just go to nVidia’s website and select the previous version or maybe 2 versions past and install one of those.
Thank you guys so much I have updated the driver and it’s working properly now
I started playing games and it’s happening again
Did you run DDU before updating the drivers as @Zszywany suggested? If not, I think that’s your next step. Here’s a guide that explains what it does and how to use it.
Thanks I uninstalled the driver by going into safe mode with networking with ddu now I’m installing the driver from nvidia
Have you watched Wendel’s video regarding cable and the handshake that happens between the monitor and graphics cards? Could honestly be your cable if I’m not mistake he stated that a recent change happened where it was causing the display to loose handshake and cause the screen to go black.
It’s been happening randomly most recently.
I watched the video how to find out if it’s the driver or the cable which is causing the problem?
I uninstalled the driver with ddu in safe mode with networking and installed the sept 2021 nvidia driver and it’s working properly I guess it was the driver which was causing the flickering and black screens
Does anyone know the best 1.4 display port cable which is 3m or 10 feet long?
Club3D or if you go on the Level1techs store Wendell sells his recommended cables there as well.
From the NVIDIA Control Panel navigation tree pane, under Display, click Adjust desktop color settings to open the page. Move the Flicker Filter slider to adjust the value. Hope it will help you.
