I've decided it's best to completely build a second pc after being unable to reasonably upgrade my too well balanced first. I will be re-using a few parts, but the main components will be new. I am having some trouble deciding on the power supply though. The system should only draw 414W and I currently have a Corsair CX430, however I'd like to overclock (will be my first time). Is my current power supply enough even for non-OC? or should I get a power supply up around 600W? Do you have any other recommendations?
Here's the parts list (re-used parts will be marked):
PCPartPicker part list: http://pcpartpicker.com/p/h8qH8d
Price breakdown by merchant: http://pcpartpicker.com/p/h8qH8d/by_merchant/
Benchmarks: http://pcpartpicker.com/p/h8qH8d/benchmarks/
CPU: AMD FX-6350 3.9GHz 6-Core Processor ($139.97 @ OutletPC)
CPU Cooler: SilenX EFZ-120HA5 86.0 CFM Fluid Dynamic Bearing CPU Cooler ($24.99 @ Newegg)
Thermal Compound: Arctic Silver 5 High-Density Polysynthetic Silver 3.5g Thermal Paste ($6.98 @ OutletPC)
Motherboard: MSI 970A-G46 ATX AM3+ Motherboard ($78.98 @ OutletPC)
Memory: GeIL EVO VELOCE 8GB (2 x 4GB) DDR3-1866 Memory re-used
Storage: Western Digital Caviar Blue 500GB 3.5" 7200RPM Internal Hard Drive ($51.49 @ Amazon) re-used
Video Card: MSI Radeon R9 270X 2GB TWIN FROZR Video Card ($204.98 @ SuperBiiz)
Case: Corsair SPEC-02 ATX Mid Tower Case ($57.99 @ Micro Center)
Power Supply: Corsair Builder 430W 80+ Bronze Certified ATX Power Supply ($39.99 @ Newegg) re-used*
Optical Drive: LG GH24NSB0 DVD/CD Writer ($15.98 @ OutletPC) re-used
Total: $621.35(not really)
