I will mostly be using it for gaming and will be building in the next few weeks. I wishlisted all the parts.
http://www.amazon.com/gp/registry/wishlist/3Q5W51Z9FSN2Z/ref=topnav_lists_3
I would prefer a better motherboard. If on budget the asus m5a97 evo r2.0 or gigabyte ga-970a-ud3p. Or a 990fx motherboard if you can afford it.
Also a better power supply. 550-650w choose brands from Antec, Coolermaster V series, Corsair (not CX or CS series), Seasonic or XFX
I would look for a different psu, I don't believe that one is even 80 plus certified.
the motherboard is a weak spot but as long as you don't plan to do OCing its should be fine.
Antec High Current Gamer HCG-520M, 80 PLUS BRONZE, 520 Watt Modular Power Supply
80 PLUS BRONZE
Just so you know.
That motherboard should handle overclocking just fine with a 8+2 power phase design.
I would get the cheaper Gigabyte GA-970A-UD3P, and then hop up to the FX-8320 or FX-8350. Also pick up a cheap aftermarket cooler like the Hyper 212 Evo since the stock AMD coolers are pathetic.
