I have a 780i mobo and two GTX 260 c216.
I really want to get the Creative Sound Blaster X-Fi Titanium - Fatal1ty Pro, but my 260 is covering my PCIe slot.
The only available slot for me is PCI and PCIe x16(tri-sli)
I am going to ust it for gaming, music and some movies.
Thanks
you can put a pci-e into a pci x16 slot you know...
edit: and i would recommend the azuntec forte, its a really good pci-e card
Sty1ez
March 15, 2009, 9:00pm
4
Yo Belial, The Fatal1ty works in the X16 slot. How ever I do not recommend that card. Highly unstable,My Recommendations are....
-Auzentech Prelude
-Auzentech AZT-Forte
or
-Creative Sound Blaster X-Fi Xtreme Gamer <---(Quality but the two are better, Creative makes crappy drivers but this card seems to be their most stable in vista and 64-bit OS's)
JB54
March 15, 2009, 10:04pm
5
Auzentech Prelude. No reason to use your 3rd pci-e 16 slot could get another gtx 260.
Xezmer
March 15, 2009, 10:23pm
6
I just purchased the Diamond Multi Media XtremeSound 7.1 Channel Sound card.. it's fantastic IMO for the price that is.
30$ at staples
50$ at newegg
I'm going to be uploading a video on it soon
Like George said, u can use a PCI-E x1 card in any PCI-E slot.
Id reccomend the Auzentech Prelude and the Forte.
go for something by creative labs
FM-Fr4gm4n wrote 2 minutes ago »
If u go with Creative, then be aware of their drivers, which are rly crappy.
k, then, i still like the cards though
JB54
March 16, 2009, 1:06am
11
auzentech much better than creative.
I have that X-fi Titanium Fatal1ty card. Amazing sound quality however, horrible drivers and support. I suggest you stay FAR away from Creative. Go with a card from Auzentech or HT Omega.
Ok I am back...
Thanks for all the recommendations.
Can you guys link me to your recommended sound cards?
My budget is $150 I cant go over that.
well, the one logan recommends is:
[url=http://www.newegg.com/Product/Product.aspx?Item=N82E16829156010&Tpk=forte]auzentec forte[/url] - low profile, pci-e really good sound card aparantly, one of the best.
if you want more power go with the auzentec prelude, but thats 175 i think
What do you all think of this headsets
CyberSnipa Sonar http://us-webstore.cybersnipa.com/p/742946/cyber-snipa-sonar-51-headset.html
Creative FATAL1TY 3.5mm gold-plated Circumaural Gaming Headset http://www.newegg.com/Product/Product.aspx?Item=N82E16826158051
Which one is better?
George wrote 2 hours ago »
auzentec forte
there is also this one AUZENTECH X-FI 7.1 PCI sound Cardhttp://www.newegg.com/Product/Product.aspx?Item=N82E16829156005
the sonar is 5.1, the fatal1ty is stereo, so its your choice, both headsets are good, you just need to decide between 5.1 or stereo
George wrote 57 minutes ago »
i like the 5.1 but the thing here is I cant find that CS sonar
123456iambelial wrote 2 hours ago »
CyberSnipa Sonar
i have the faital1ty its decent sound quality but made of cheap plastic and dosent feel solid very flimsy the ears are made of velvet and it gets hot after a while kinda like earmuffs wire is very flimsy
but great for the price well what i paid for it $25 bucks for $50 never in hell
if anyone know a cool sound card for home studio with a fair price pls TELL ME!!!
ehum im currently trying to record metal in overall instruments. I have a KB37 from line6 but i want something better.
