I need mor infofor this monitor any here test it?
If you want a 144hz 1080p monitor with freesync, just get one of the 21 or 24 inch ones. 32 inches and 1080p is a terrible pixel density. The pixel density of a 32 inch 1080p monitor is 68.84. Compare that to the commonly accepted and consensus ppi of close to 100, and you start to realize how low it is. 21 inch 1080 is 104.99, 24 inch 1080 is 91.79, 27 inch 1440p is 108.79, and 42 inch 4k is 104.9.
Here's a $130 cheaper 24 inch 1080p 144hz freesync panel with 4.3/5 stars on amazon:
^this. I made the mistake of buying a 27'' 1080p monitor and I could notice the difference between that and my 24''. Really 24'' is about as big as you should go at 1080p.
Do you consider the possibility of the guy using the monitor from a distance?
If you need it as a standard monitor for up close usage - get smaller monitor or higher res...
I know 144Hz is better than 60 in 7 out of 10 times, but c'man... You know 1440p freesync is better...
