So i am going to buy my new PC very soon and the PSU(Corsair CX 600M) is out of stock on newegg. So i need a new one that is 600 watts and is modular and if you can red. Any help is greatly needed!
-Ianeo5
-Ianeo5
Why do you need 600 watts?
Try the corsair CX750M. I have that PSU
most people don't need 600w what's in your system and how far are you going to overclock
rosewill green series 630w PSU is good one, the capstone 650w one is even better
I need it for OC ing and i am going to add another GTX 660
What is your budget?
$80 USD
I'd get a Lepa G650 :)
Its out of stock on newegg
How about this PSU? http://www.newegg.com/Product/Product.aspx?Item=N82E16817182132
how many PCI-E power connectors will you need in the end? that only has 2 6+2 plugs
you could probably get away with using 2 molex to 6 pin PCI_E adaptors that just about every card comes with
but yeah its a decent PSU, don't forget the promo code as it shave's off 20 bucks
im going to get the Roswell hive or should i get the Corsair CX 750M?
Don't base your PSU decision off of modularity. Get the Rosewil Hive.
The Corsair CX series claim to have "Japanese" capacitors, which makes them sound nice. Correction, they have ONE Japanese capacitor, rated only at 85C, not the standard of 105C, with the rest of the caps being Tiawanese or Chinese, cheap shitty ones.
The Rosewill Hive is a vastly better PSU :)
