I want to spend $500 dollars on my PC. I currently live in Australia. the 2 main games i usually play are LoL and CS:GO. The reason why i want a new pc is because of the framerate i have right now (it's horrible!) I also want to play other games at a good resolution like let's say, Sleeping dogs and Red faction. I won't really need that much for storage but it's nice to have 1TB. And also maybe a sound card? (I use Razer Kraken Pro)
http://au.pcpartpicker.com/p/2gMiA
Upgrade the APU (CPU) latter when Kaveri comes out and you can get cheaper RAM if you want.
idk how the prices over there are, but i've put together a reference to go off of. i tried putting most of the cost into the GPU, and i might have gone a little high, but it'll make sure you're good to go for a while. and i made sure you had an ample amount of power to run off of even if you got upgrades in the future.
http://pcpartpicker.com/user/ET_CaughDrop/saved/359U
as for a sound card, if you're wanting to take full advantage of that kraken, then you're gonna need to get one with a Headphone Amplifier, and they're a bit pricey. the one i'm using was $120.
Hope this helps out a bit.
Remember that I am in Australia so the power supply and another part isn't available here
Bit over, but AU has such a sad selection of parts :(.
http://au.pcpartpicker.com/p/2gT69
APU build, with future upgradeabilty to Kaveri.
You could also put in a GPU later if you wanted.
Curious what is Kaveri? Are there any alternatives for the case (maybe cheaper or slightly more for better performance)?
