I need a new power supply
My old one, still in use, makes incredibly loud clanging sounds (as if the fan is cutting into a wire, even though it isn't, I've checked) and is dubiously unreliable. So, I need a new reliable and cheap-ish power supply, hopefully quiet too, but that isn't needed, and I thought coming here is the best thing to do since most of you have had hundreds of power supplies that have been over-used and abused until you've found a perfect reliable PSU. I don't need a very high power PSU, but around 600w would be fine.
Thanks, in advance guys!
http://www.newegg.com/Product/Product.aspx?Item=N82E16817207013
XFX 550W pro. decent unit, for a good price. ☺
How about this one?
http://www.newegg.com/Product/Product.aspx?Item=N82E16817151136
Seasonic S12G-550W. Gold efficiency, OTP protection (Over Temperature Protection), and only $5 more expensive.
EDIT: The Seasonic is $15 more expensive after the mail-in rebate, didn't notice that. Thank you for pointing it out, Mistery.
that seasonic is also a great choice gold certified.  is allways nice, for $15 could be worth it. ☺
I would personally recommend the Antect HGC 620w M to anyone, I have used it constantly for the past year now and have had no problems. It has a 5 year warranty, all Japanese capacitors, and over all a really good build quality. And of course it is 80 plus certified. On top of all that awesome stuff, if you delve a little deeper into its review it provides some of the cleanest power out of almost all power supplies. Well maby other then its bigger more expensive High Current Platinum brethren.
