I want a storage solution for my linux mobiles to connect to my main desktop at home while I am out. I'll be going down to floridia soon, maybe, and while I am there I will need access to my files. Now I could use something like FTP or set up a mirror for myself but I have been listening to the linux action show and heard some things about different solutions out there.
Over all I want something that will connect from anywhere on the net, can be encrypted, mounts in a folder and presents icons like dropbox, and on selecting a file it will download it, preferably via P2P, to the outer machine. I've thought of making my own solution in GIT but I'm sure that somewhere there is something like this that might work. Maybe even an SVN type of system?
Maybe, though I don't want a separate server like a nas. I just want my machines to connect to each other. If I had money or drives for a NAS I might give that a shot but thats not really an option for me at the moment...
SeaFile is Windows based, free, and super easy to use + install. If that doesn't suit your needs, install Filezilla, and create a SFTP. If you wanna be even more secure, rent a VPN, or even create a virtual machine running OpenVPN, and connect to it when you want to access files.
If you just want your computers to have a sync of the same folder then starting up a next cloud instanace is a bit over kill.
If you are running windows: Resillio is simple and works.
if you are using linux you can run rsync in cron job to sync a folder with file changes. These are to have in house solutions. if you don't mind your data in the cloud, then dropbox is simplest.
Also consider buying or rigging some type of networked/IoT power outlet, so you can hard reset the machine remotely in case of a crash. There's nothing worse than calling someone across the country and asking them to go to your house and reboot a crashed server. -_-
I also have splashtop streamer installed on both my server and workstation. Server doesn't boot to a DE, but I can start one and splashtop into it if I need to; it helps to troubleshoot other problems.
It will be a form of linux of some sort. Possibly slackware? I'm doing tests today so it might just end up being ubuntu mate or KDE-Neon at the end but I am hoping for a form of slackware.
I have a couple machines that I use. If I need one specific file that is somewhat important I don't want bits to be missing. P2P always does the whole file, which is my preference. I can't miss anything, unlike HTTP or FTP where I have had files come incomplete.
Thank you for the suggestion though I will look into it.
