I have been looking for a new monitor recently and thought maybe I could use a little help. I would like to keep it under $200 if possible. It must be at most 24 inches because if it is an bigger it will not fit on my desk. I really don't care for any resolution bigger than 1900x1080. Thanks for the help.
Best I could find for $200 ... maybe someone will find better for you.
Please keep in mind that these are offered just for info something to look for when shopping & not my personal recommendations.
I recommend that you look at a monitor before buying ... unless you get a lot of favorable feedback here.
23" Asus LED 1920x1080p 5ms IPS
http://www.amazon.com/Asus-MX239H-23-Inch-LED-backlit-Frameless/dp/B00B1IAL7W/ref=sr_1_2?s=pc&ie=UTF8&qid=1407688561&sr=1-2&keywords=1080p+monitor
24" LG LED 1920x1080p 5ms IPS
http://www.newegg.com/Product/Product.aspx?gclid=Cj0KEQjwsJyfBRC729Oy5Pf26ekBEiQAYtd9QW8A4XmGvxNC2WOG10JxP2sBweqEJzsRbZpFQPvgUOMaAgud8P8HAQ&Item=N82E16824005603&nm_mc=KNC-GoogleAdwords&cm_mmc=KNC-GoogleAdwords-_-pla-_-LCD+%2f+LED+Monitors-_-N82E16824005603&ef_id=U7R9AgAABJfJVatw:20140810165454:s
I have found some decent 22" and 24" LCDs at thrift stores like Goodwill & Value Village in the $15 - 20 range.
You might check some pawnshops or ??
i have a samsung 23 inch, but its a TN panel. Go with one of those mentioned above. They seem better.
ok one other thing I forgot to mention is that I would prefer DVI which the Asus lacks and the LG is a little pricey also I don't know of any pawn shops near where I am but thanks for the suggestions.
Yeah the Asus does include a DVI-D to HDMI adapter so kinda
http://www.newegg.com/Product/Product.aspx?Item=N82E16824236174&ignorebbr=1
http://www.newegg.com/Product/Product.aspx?Item=N82E16824014377&ignorebbr=1
http://www.newegg.com/Product/Product.aspx?Item=N82E16824236288&ignorebbr=1
Just a couple suggestions , I like the Ben Q if its for gaming. TN panels have great response , do you want better color or is response more important.
thanks for all the suggestions I have chosen the asus 23.6 inch monitor
