ok so i have $390.00 and i am in the states i am looking for a mobo that stupors 1866 ram as well as has on board video i perter intel over amd BUT if you can find some thin to change my mind PLEASE i beg you show me the three companys i do like is asus as well as gigabyte and evga also id like some thing current :) if this topic is in the wrong area i am very sorry i am new to this site
AMD FX8350 with Asus: http://pcpartpicker.com/p/m155
AMD FX8350 with Asrock: http://pcpartpicker.com/p/2BA40
Intel i5-4670K with Msi: http://pcpartpicker.com/p/129Wg
http://pcpartpicker.com/p/1O42V Here's what I came up with. Do you plan on overclocking? If you don't you can save some money.
I thought the same thing but he said on board video :(
nope no OC
the xeon has NO igpu. so that does not work ☺
right on you guys are F ing AWESOME thank you so much for all the help and the FFFAASSSTTT reply's wow
http://pcpartpicker.com/p/2CD4f
this should work well.
also if others have any input it will be useful
my bad, clicked the wrong thing sorry...
yeah well i was also thinking about a kaveri APU. That would also not be a bad choice.
http://pcpartpicker.com/p/2G05f
haha no problem happens to me somethimes to ☺
id loke some thing that would be good for video editing would the APU still be a good choice? what about cuda cores? i use both sony vegas as well as after effects
If this is a web browsing machine (hence the on board video) then the kaveri is a great choice. Not as strong as the I5 but in web browsing or a home theater pc, who cares. Absolutely the noticeable difference in web browsing or video consumption.
video editing on an apu or igpu? how are you thinking to accomplish that? offcourse it will work somehow, but why? cuda cores on an igpu? Sony vegas, prefers open CL.
well the on board video is only temp till i can afford a nice video card but i was wondering which setup would be a better route?
wait a second i´m thinking about something else ☺
Here ya go: http://pcpartpicker.com/p/2hI5E
This will do better, and you can allways decide to upgrade your gpu lateron. but still you can benefit the open CL power of the 7770 in sony vegas.
MisteryAngel you ROCK! i know what im gettin now :D
