I need a case
I have been looking around for a case and I really can't find one cheap but very good. My specs are;
Proccesser: http://www.amazon.co.uk/gp/product/B007RUZKK6/ref=ox_sc_act_title_3?ie=UTF8&psc=1&smid=A3P5ROKL5A1OLE
Motherboard: http://www.dabs.com/products/asus-p8z77-v-lx2-s1155-intel-z77-ddr3-atx-8BYD.html
Graphics Card: http://www.ebuyer.com/388867-powercolor-hd-7870-pcs-vortex-ii-edition-2gb-gddr5-dual-dvi-hdmi-ax7870-2gbd5-2dhppv
Hard Drive: http://www.ebuyer.com/319639-seagate-1tb-barracuda-internal-hard-drive-st1000dm003
Ram: http://www.dabs.com/products/crucial-8gb--2-x-4gb--ballistix-sport-ddr3-1333mhz-cl9-1-5v-240pin-7Y8R.html
PSU: http://www.amazon.co.uk/Corsair-Builder-Series-Bronze-Supply/dp/B009RMP2VE/ref=dp_ob_title_ce
This is £568.56 out of my £600.00 budget, with some including postage and others not. I really need a case for this to be real!
Thanks guys
http://www.newegg.com/Product/Product.aspx?Item=N82E16811119233
I recommend the Fractal Design R4 or XL R2 if you want a really high quality case for a great price. If you have more money to spend, the higher-end Corsair cases, such as the 600R, 800D, and 900D, are great as well. If you want to go all out, a Silverstone Tenjin TJ07 or Case Labs case would work. Fractal Design makes some great products, though.
http://www.ebuyer.com/390898-casecom-cs-13-case-cs-13 should keep you in budget
I had been looking at the http://www.amazon.co.uk/BitFenix-Shinobi-Midi-Tower-Chassis/dp/B004ULZA82/ref=sr_1_1?s=computers&ie=UTF8&qid=1361281302&sr=1-1 or the http://www.scan.co.uk/products/sharkoon-vs3-v-black-green-atx-mid-tower-case-w-o-psu-usb-30-120mm-fan but I could use some peolpes opinions... thanks everyone :)
Shinobis are great cases, thats what id go for.
go ebay buy a cheep one :P
is there a way to upgrade the front to usb 3.0 without buying the £10 more one?
