I need a $450 build (parts preferably from Amazon or Newegg) for gaming. I will be using some Adobe Creative Cloud as well.
Things I need:
Case (To save some money, go with a case with a built-in PSU if you'd like)
PSU
Keyboard
CPU
GPU (If it's an APU, I don't need a GPU)
RAM
HDD
Windows 7 Home Premium
Thanks. I also want to be able to play Borderlands 2 at 720p with Medium Settings.
EDIT: I also want to do some rendering and uploading to YouTube.
EDIT 2: Here is my current AMD build option: http://pcpartpicker.com/p/OSFQ
Here is my current Intel build option: http://pcpartpicker.com/p/OPHA
http://pcpartpicker.com/p/OTKn
CPU: AMD Athlon II X4 640 3.0GHz Quad-Core Processor ($73.61 @ Outlet PC)
Motherboard: Gigabyte GA-M68MT-D3 Micro ATX AM3 Motherboard ($44.98 @ Amazon)
Memory: Corsair 4GB (1 x 4GB) DDR3-1333 Memory ($25.99 @ Newegg)
Storage: Hitachi 500GB 3.5" 7200RPM Internal Hard Drive ($52.98 @ Outlet PC)
Video Card: MSI GeForce GTX 650 Ti 1GB Video Card ($119.99 @ Newegg)
Case: Fractal Design Core 1000 MicroATX Mini Tower Case ($37.99 @ Amazon)
Power Supply: Corsair Builder 430W 80 PLUS Bronze Certified ATX12V Power Supply ($30.98 @ Newegg)
Keyboard: Adesso AKB-131PB Wired Standard Keyboard ($8.98 @ Outlet PC)
Other: Microsoft Windows 7 Home Premium SP1 64-bit - OEM - DELL ($59.00)
Total: $454.50
http://pcpartpicker.com/p/OUMi
this or something along these lines would be a good choice. i would encourage you to get the best gpu you can afford, i have a 7770 in there if you can find another 50 bucks though i would recomend a 7850.
best of luck, and stay away from the APUs!
there is no w7 or Keyboard in that ^^
you are correct, im sorry i missed that part...
Like cooperman said, no Windows 7 in there :(
i Agree with this build whole heartily i would however recomend a 7770 over a 650 its better acording to toms hardware and cheaper. all in all very good build.
its not better than the 650(ti) maybe the 650 but there 2 differnt cards
[img]http://i.imgur.com/yGPM9Ev.png[/img]
[img]http://i.imgur.com/4kl3ZIX.png[/img]
