I might have found out why Anandtech got bad latencies with their 9950X
Thanks to @quilt giving me that answer to my query about PyPrime, I noticed something that could well explain why Anandtech got the bad latency results for their 9950X review.
It appears that presently, if the FCLK is not clocked to 0.67 of the data rate of the RAM (or one third of the MT/s) assuming that UCLK=MEMCLK has been set in the BIOS, then the memory performance is suboptimal, as I shall demonstrate below.
Let’s start with my “Bigger Number Better” mistake, which gave me a performance boost with my 7950X but was detrimental to my 9950X performance. I am running a RAM speed of 6200 MT/s with an FCLK of 2167 with my 9950X, and here is the PyPrime result:
In the second example, I have the RAM running at 6200 MT/s and the FCLK running at 2000:
In the final example, I have the RAM running at 6200 MT/s and the FCLK is set to 2067:
This was when I was running my VDDQ voltage the same as my RAM voltage, namely 1.4 Volts
When I set my VDDQ voltage to 1.25 Volts (leaving my RAM voltage at 1.4 Volts) I got the following PyPrime result:
I looked at the Anandtech specs for the RAM, and they were running 5600MT/s RAM, and I am pretty damned sure that the FCLK in the BIOS defaulted to 2000 instead of 1867.
This would I think account for the strange latencies that they were getting compared to a 7950X.
Are you talking about the cross-CCD latencies? Those don’t have anything to do with the RAM frequencies, and I believe the FCLK impact on it doesn’t explain at all the higher latency that happened from Zen 4 to Zen 5.
To measure cross-CCD latencies, you can use a tool like this one:
Anyhow, seems like AMD already released a fix for this within their firmware:
Why don’t you try it?
If I am wrong, then I am wrong.
Because I don’t have a 9950x, duh.
Again, the thest you ran is not measuring cross CCD latency whatsoever.
I gave you the proper tool to measure it. If your idea is correct, you could simply make use of it and see the latencies increasing/decreasing as you make those changes you mentioned.
Assuming I have Linux installed.
Can’t find anything that will give me the results in Windows.
I don’t think it has anything really specific to linux. Anyway, I don’t have windows so I can’t test it out.
You could also try your luck with clamchowder’s tool:
But it’s not as easy to use.
I’ve heard that capframex has such tool, but I’ve never used it either:
https://x.com/CapFrameX/status/1447614366627647489
It’s been fixed.
https://www.overclock.net/posts/29367748/
Hope so, and I am looking forward to testing it out.
