I made the Switch and I regret nothing!
This is not another 30 day challenge. This was a most likely permanent, and at least “indefinite” at this point, since I have no foreseeable plans to switch back. For me its easy since in windows most of my workflow is browser based or opensource Linux native programs ported to windows (gimp, Shotcut etc). I do have a 5 PC license for the business for 365, but WPS office is pretty much there for local machine use and I can log-into the portal and edit any collaborative documents with the browser based 365.
The machine is all AMD so the GPU is actually much more stable and reliable for video rendering in Linux (no more driver crashes!),
Network shares did crash when trying to mount in Dolphin, but the other file managers and doing it in terminal was fine.
Oooooohhh Studio is a very specific use case… Very much workstation/production vibe. It should be nice and boring.
So far it seems like you don’t need stuff on the bleeding edge (like for gaming) so you should be able to settle down.
IIRC DaVinci has Linux binaries so there is that if you need something more polished than GIMP your current video editor. I haven’t had a look myself because I don’t have the use case anymore.
I liked studio because all the apps I use were baked in at install. I am a KDE person, and since 2004 and the Mepis distro I have ran linux in some flavor on either my laptop, dual booted the desktop, or both. This is just my first time with no “safety net” on my main desktop and just went all in as the only OS installed.
This is the fist time daily driving Linux I didn’t think “this is great except X is missing”. I am giving up gamepass, but with three gamer daughters I wasn’t buying three accounts, they had a shared one, and one kid could use mine if they both wanted to play the same game, so I didn’t really give that up, just let my kids use it more, I also have a “guest gaming PC” i can use if Gamepass has anything I feel compelled to play. The last couple gamepass games I liked are also available on steam and are not competitive with anticheat so I could just buy it on steam in this machine if I like it enough.
Nice
This is the way. Else it is “too convenient” to stay in the cage :slight_smile:
They do, and it works nicely.
One issue at least on Fedora 40+ is BlackMagic using some outdated (?) libraries that need to be removed for DaVinci to work right.
The script that I found a long while ago:
#as non-root
#adjust version in line below:
sudo SKIP_PACKAGE_CHECK=1 ./DaVinci_Resolve_Studio_20.0_Linux.run
sudo mkdir /opt/resolve/libs/_disabled
sudo mv /opt/resolve/libs/libglib-2.0.so* /opt/resolve/libs/_disabled
for lib in \
  libglib-2.0.so.0 \
  libgobject-2.0.so.0 \
  libgstreamer-1.0.so.0 \
  libgstsdp-1.0.so.0 \
  libgstwebrtc-1.0.so.0 \
  libgio-2.0.so.0 \
  libgmodule-2.0.so.0 \
  libgstrtp-1.0.so.0 \
  libgstpbutils-1.0.so.0 \
  libgstbase-1.0.so.0 \
  libgstvideo-1.0.so.0 \
  libgstaudio-1.0.so.0 \
  libgsttag-1.0.so.0 \
  liborc-0.4.so.0; \
do
    ln -sf /usr/lib/x86_64-linux-gnu/$lib /opt/resolve/libs/
done
I’m sorry to hear that. Dolphin and cached Samba shares have eaten my KDE Plasma 5 desktop in the past, I hope this doesn’t bite you again.
Good luck with your onward journey!
K3n.
Yea I know the most popular option is to edit in resolve but Its too advanced for my low quality videos. I don’t want to relearn anything. Also I might have to take it seriously at that point. My MSP business has a dispensary in its client base that I also was brought in to produce their podcast on Ruble & YouTube channels. Which turned into FB reels as well. So I probably should try and get better.
I had just re-cased my workstation when I decided to switch. So i edited the case review in this thing and It was so much easier than windows and at the same quality and rendering on the GPU seemed noticeably faster in linux.
Its been way smoother than I expected. Other tings I found easier:
Screen Shots and annotation: I am using Gradia to take screen shots an annotate it directly. Instead of in windows having to use the snipping tool, and then open the file in another program to add notations or whatever. So much easier and much less time in different apps.
RDP-- How does Linux handle this better??? Using Remmia I have way more granular control over quality. In the remote session it is so smooth you can forget your remoted into a headless machine.
Webcam: I had a 1080p Razer webcam, that while decent quality wouldn’t work in windows without their software. Now not only did it just work, but OBS has control over all the quality and color settings that were locked out in windows!
Everything loads faster, just feel more responsive, and workflow is easier.
I will not be switching back.
Thats awesome. Love your setup. I’m running windows 11 on my MS-01 (with nvidia A1000) and I started testing Omarchy on an AMD mini PC (cheap $300 unit with 16GB ram) but ended up switching to bazzite. I’m loving bazzite, but the immutability and containerised approach causes issues with apps like kdenlive. Great for development environment and steam works flawlessly.
Come back in a year from now, daily driving this and get your 1-year linux challenge badge!
I love those mini Pcs! I have converted a bunch of business over to them phasing out older windows 10 pcs that won’t update. So far I’ve converted the back office of a large retail store, a painting business, and a reallty office.
As for my Linux switch all the steam games I have tried so far work great.
Oh I am in it for the long term. The computer feels like a new PC. Workflow is more efficient, and everything is running better. Zero reason to go back or switch distros.
I have a video up today on the switch I Don’t want to break any rules about self promotion, but I go over everything in it. Its on my channel and live if anyone is interested… and for the record I am not a Youtuber, nor do I want to be, I am an MSP owner who happens to video some of my personal and professional projects.
And to my knowledge the only MSP/IT Contractor with an Amish built office.
So even though I am not a streamer of any sort I decided to stream some games to see how it compared to windows and Damn…
OBS + Razr 1080p webcam + multiple screen shares and transitions and running virtual camera for discord (why not stream t my discord and you-tube at once), something that would of been a choppy in windows was smooth.
all playing at 1440p UW. RDR2 - Shadow of War - Hogwarts Legacy. All ran better than windows while streaming.
This is literally like a new PC, and since its not a Windows machine I didn’t have a single Radeon driver crash trying to play and do multiple encodes.
Over a month in, Zero issues.
I forget I am even running something different. Everything is working as it should. Picked up a new Brother Lazer printer for the office and it found it instantly. Easier than any windows device. Any games I have bought in steam run great. Only noticable difference is with proton the initial load time is longer, but the game runs smoother and streams better than windows. The only time I have touched terminal was for PIA and I don’t think that counts. PIAs Linux installer is a .run file you have to open in terminal. So I just litterally opened the file in terminal, didn’t have to type any commands, just run the script. Microsoft would have to pull up to my house with a dump truck full of money to get me to switch back.
Welcome to the Linux crew. I ditched Windows for home use 2 years ago and it’s been wonderful. I feel like my computer is “mine” again. I’m using Fedora Workstation.
The only thing that bothers me is I can’t play BF6 simply because of the anti-cheat. But I keep another SSD with Windows installed for that and potential emergency situations.
Thanks! but I’m not completely new, just coming back. and Just the 1st time as the ONLY OS on my main PC.
My first distro was Mepis in 2004.
was half in and out dual booting and tinkering through windows 7.
Gaming and Quick-books always held me back form 100% committing
Windows 8 forced me to daily Linux allot more except for gaming, and gave up quick-books. (converted allot of grandmas to Ubuntu duing that time because 8 was that bad)
The Windows 10 RC, pulled me back to almost 100% Windows except for giving older devices a second life, but my desktop was ONLY 10 (was directly called a traitor by one of my regulars I converted to Ubuntu, I also taught her to torrent and she had a media server (ether pre-plex or before I new about them)
In the meantime…
With Chromebooks in the time becoming popular and Quickbooks going cloud/mobile. I had one client during the pandemic switch accounting to chromebooks and quickbooks cloud. I switched myself to “Intuit self employed” and that hurdle was gone. Quckbooks was no longer an issue. Even the my 365 subscription worked on mobile and in a browser so that was also surprising
SteamOS changed gaming
This year I have built 8 gaming PCs for kids as young 16 (not counting my own) and as old as 23 who NEVER used windows before the PC I built. They all grew up on chrombooks, and consoles for gaming. They didnt have a PC at home ever, and schools were all chromebooks.
People sleep on chrome, but if you just look at the US, thanks to 90% of schools using them (96% of schools are MS free counting Macbook/imac districts), the US market-share is over 8%!
when i re-cased my workstation, I just got the urge to switch, so I did! First time not dual booting and I am glad I did it this way. The amount that has changed is immense, and everything I use just works now!
How I grew Up:
Next Generation:
Chromebook Kids growing up is interesting to see!
So I had an Ubuntu Studio update Brick Steam and proton.
None of the steam games would work.
Tried PopOS for a a few days. The new Cosmic is not ready for prime time on a main desktop. Worse audio issues, as far as ignoring what sound device to use no matter what I set in the settings.
sometime discord would freeze, or open in both screen,in a weird app mirrored mode.
Desktop was completely unstable graphically running 3 displays, glitches were reduced when running two.
Then games kept randomly crashing to a weird window mode that wouldn’t fit, and couldn’t go full screen. Happened mid stream and took 4 relaunches to work properly. (sorry if this violates self promotion rules but its very relevant to my Linux switching journey so far)
Warning frustrated foul language:
So Tuesday I installed re-Ubuntu Studio, this time going to the LTS version. While its behind some eye candy stuff, its very stable, Dolphin mounts my network shares fine now, OBS is pre-installed with plugins and virtual camera support. Any little issues I had with the newest version, are not present on the LTS.
So That is the last time i try and jump to new distro with this machine. PopOS cosmic is fine for a laptop OS, but not my daily workstation.
I’m guessing now the new MacBook Neo is going to shake this up a fair bit. I got my wife one this week, she only does emails and light word-processing type of stuff, and for the price that thing is great. Quality and feel of it is miles ahead of any Chromebook I’ve come across.
This was an issue for me as well on many distros and PCs. My workaround was using Smb4k. That was a bug in up to KDE 6.4.x
BUT starting KDE 6.5 this is fixed and accessing network shares (like a W11 shared folder) works as it is supposed to. (Fedora/Kionite 43).
There were some other issues 6.5 resolved for me. Based on that experience, I recommend to use distros that update the DE.
Little improvements like this give me hope we are going in the right direction
Going backwards actually fixed it for me. Going to the previous LTS version of Ubuntu Studio on an older version of KDE all my network shares mounted fine, and all my issues completely disappeared.
