I lost my data from my hard drive need help
ok guys so i went to my computer and i had my local C drive than a D drive that was only 100mb than my 1tb drive so i went to computer management and added the 100mb drive and the 900 gb drive since they  are the same one and know it has that the volume has been deleted and i cant open it, it tells me to format it but i dont want to lose all my data there is there a way to fix it.
thanks dudes
These should help you, man
http://www.partition-recovery.com/
http://diskdigger.org/
http://www.easeus.com/partition-recovery/
Also try not to write to the drive. The less, the better chance of file recovery.
thanks bro
Yea, I remember the first time I ever accidentally deleted a partition. It was a 400GB partition with ALL my music. I started banging my head on the wall for hours and didnt even try to recover it until I was done with the wall banging xD
I was able to recover the partition, though. It is a scary feeling.
try file scavenger it worked out very well for me.
you need to pay for it but i'm sure you can find something on piratebay ;)
