i just built my first pc the case light turns on nothing else no fans plz helppppp
That's a little light on the info, there. This may sound silly, but have you gone over all the cables? Is everything connected? It's very easy to overlook something.
i made sure everthing connected about 100 times i stayed upp all night
Is the cpu fan spining?
no
the cpu fan is not spinning nothing is showing any sighns of working
Have you conected the 24pin power and the 4pin power to the motherboard?
yes
Then you may have a faulty psu :/
just check the power switch is connected rigth on your mobo and at the back of the case (some cases are not conected to the buttons on the front and you have to conect them your self)
