I want to buy a 600w PSU but i have a 24pin and a P4 conector (4pin atx 12v or whatever ther are called) and i can't find a PSU with 4 pin connector i have gigabyte GA-H61M-S2PV motherboard.
most psu's have them.
Yes most of the time the CPU power plug (now usually 8 pins) will split into two 4 pin connectors. You just use the one.
This a decent one that is semi modular ... but it depends on what country you are buying in.
Corsair CX 600W 80+ Bronze Certified Semi-Modular ATX Power Supply
http://pcpartpicker.com/part/corsair-power-supply-cx600m
tnx for the answers ;)
