I have a hardware dilemma
Hello Logan, Wendel, Pistol and Qain. Love your channel, love the Tek. I would note that I'm British so the pricing is more expensive in the UK.
Basically the problem I have is that I've got a GTX 560 that I got with my PC about 2 years ago with a intel i7 2600 Quad Core @ 3.4ghz. My GPU is lacking and I want to get a new graphics card because the FPS in games is lacking to what I would like, I've got about £550-£600 at a push. I'm not sure if I should go straight for some crazy GTX 780 like the one below:
http://www.overclockers.co.uk/showproduct.php?prodid=GX-309-AS
Or if I should get a decent GPU and a new decent processor. Sometimes my computer freezes up which I don't know why, I've got 16GB of Ram in 3 sticks, 2x4 and a 8 stick. My computer was decent 2 years ago I guess but I need to upgrade now as the hardware is lacking.
My computer at the moment:
- GTX 560
- Intel i7 2600 Quad core @ 3.4ghz (8cpus)
- 16gb of Ram
Could I get some suggestions on what you think the best course of action would be, to get a very good GPU or a good CPU and good GPU, please?
- Jamie
I would get a very good GPU and get rid of the 8gb stick of ram and get a matching set of what is on your board the 2x4gb ones and you will be good you could also just forget about 16gb of ram you want to make sure your ram is the same
Did you read the thread rules? This is a what-hardware-should-I-get question, in many cases the forums would give you a better answer than those 4. Only use Inbox.EXE for more personal questions like what slippers Logan uses.
It's just that this falls into the CPU and GPU category, the Build a PC is for new PCs which mine isn't. I wanted to know their suggestions.
Placing it in Build a PC would work. Logan and the crew wont answer this most likely. They get these questions very often and they have even said its not supposed to be there.
ragingh4vok gave you the right answer. 8GB of decent RAM is better than 16GB mismatched RAM.
If you're looking for a decent GPU, take a look at the GTX 770. It's about the right price, I think.
Also, make sure your PSU is ok with the upgrade.
If my question falls into multiple categories, I'd just drop it into General..
