$ sudo dnf update
created by dnf config-manager from ppa:obsproject/obs-studio 0.0 B/s | 0 B 00:00
Error: Failed to download metadata for repo ‘obsproject_obs-studio’: Cannot download repomd.xml: Empty mirrorlist and no basepath specified!
Ignoring repositories: obsproject_obs-studio
and i don’t know how to fix it. It’s not in the dnf.conf
Look under /etc/yum.repos.d./, there should be a .repo file corresponding to your command. Most likely it will be named something likeobsproject*.repo.
For backwards compatibility there’s a yum command, but it just points todnf.
$ ls -l /usr/bin/yum
lrwxrwxrwx. 1 root root 5 Jun 2 21:50 /usr/bin/yum -> dnf-3
In the early days, while dnf was still being developed, it had to co-exist withyum, so the repo definitions had to be the same otherwise they wouldn’t be compatible with each other. Now yum is gone, but the repo files are still in the same location and in the same format. This also allows interoperability with Scientific Linux, RHEL, Centos, etc.
