I have an ubuntu server setup that was working to auth users via AD on 16.04. I have since updated to 18.04 and somewhere along the way no one can authenticate to the share anymore
testparm output:
Processing section "[X Drive]"
Loaded services file OK.
idmap range not specified for domain '*'
ERROR: Invalid idmap range for domain *!
Server role: ROLE_DOMAIN_MEMBER
Press enter to see a dump of your service definitions
# Global parameters
[global]
dns proxy = No
domain master = No
local master = No
log file = /var/log/samba/log.%m
map to guest = Bad User
max log size = 1000
obey pam restrictions = Yes
pam password change = Yes
panic action = /usr/share/samba/panic-action %d
passwd chat = *Enter\snew\s*\spassword:* %n\n *Retype\snew\s*\spassword:* %n\n *password\supdated\ssuccessfully* .
passwd program = /usr/bin/passwd %u
preferred master = No
realm = MWSC.MODWHOLESALE.COM
restrict anonymous = 2
security = ADS
server role = member server
server string = %h server (Samba, Ubuntu)
unix password sync = Yes
usershare allow guests = Yes
winbind enum groups = Yes
winbind enum users = Yes
winbind offline logon = Yes
winbind refresh tickets = Yes
winbind use default domain = Yes
workgroup = MWSC
idmap config example:range = 10000-9999
idmap config * : backend = tdb
map acl inherit = Yes
store dos attributes = Yes
vfs objects = acl_xattr
[printers]
browseable = No
comment = All Printers
create mask = 0700
path = /var/spool/samba
printable = Yes
[X Drive]
access based share enum = Yes
comment = Storage Drive
create mask = 0755
inherit permissions = Yes
path = /storage
read only = No
valid users = "@MWSC\Domain Users"
write list = "@MWSC\Domain Users"
wbinfo -u outputs a valid AD user list
wbinfo -g outputs a valid AD group list
I also have a nextcloud server and users have no issue logging in with their windows creds so the server clearly can auth correctly, its just samba that doesnt seem to work.
when I do smbclient -L localhost -U [my AD user] I get:
tree connect failed: NT_STATUS_ACCESS_DENIED
if I fail to enter my password it gives me:
session setup failed: NT_STATUS_LOGON_FAILURE
so it seems that passwords are working and its just a permissions issue on the share.
Permissions for the dir are drwxrwxrwx+ 1 root root 416 May 13 08:42 storage
I’m not sure where to go or what to do from here. Any ideas?
