I am building a pc
Hey i am builing a pc to be able to play games on hi to ultra setting in 1080p or 720p and recordthem. My buget is $700. The games i want t record are mostly fps game like cod battlefield and minecraft. If there is anthing that you could tweek to make better please respond.
Here is my build:
AMD FX-6300 3.5GHz 6-Core Processor
Biostar TA970 ATX AM3+ Motherboard
Corsair Vengeance LP 8GB (2 x 4GB) DDR3-1866 Memory
Western Digital Caviar Blue 1TB 3.5" 7200RPM Internal Hard Drive
Sapphire Radeon HD 7950 3GB Video Card
Thermaltake Commander MS-I ID ATX Mid Tower Case
3 x Cooler Master R4-L2R-20AC-GP 69.0 CFM 120mm Fans
Thermaltake SMART 750W 80 PLUS Bronze Certified ATX12V Power Supply
Microsoft Windows 7 Home Premium SP1 (OEM) (64-bit)
You're going to have trouble with that GPU, save up another $80 and get a 7870
And you only need 8GB of ram for gaming.
http://pcpartpicker.com/p/1tYCK
http://pcpartpicker.com/p/1tTx8
Merry christmas..
Thank you, i wil look into a differnet GPU. On the ram I am looking into starting to record and post gameplay and more ram helps me render faster and i can run more programs at once with more ram.
I have had a broken RAM stick for a while and I have been rendering 50GB files with only 4gbs of single channel memory. 16gb is unnecessary for gaming/recording unless you plan on doing heavy editing in AE. Use 8gb of ram and buy a better GPU
32bit windozzz?
You'll need a better powersupply than that unless you want your house on fire and 16GB won't be able to be utilised in rendering/recording with a 650.  This build will let you render really fast and record with out much FPS drop, and when you aren't recording and just playing games you should be able to get 60+ FPS on any game high-ultra settings.
http://pcpartpicker.com/p/1u8mD
Total After MIR: $663.31
Here is the corrected build sorry about the problems
diabloteks are fire starters
