I am building a new gaming PC, Need Help
hello, so recently my gaming pc that i built a while ago (specs on my profile) has been lacking with all these new games coming out (metro last light) and i fear it wont be able to handle the games that come out for the new PS4 and Xbox One (GTA V, Battlefield 4) so i decided to build a new computer and i need help picking out parts that have the best bang for buck. i also will like to run 3 monitors in the near future. i would like it to be amd if possible (amd 8350). i amlooking at around 1000$ to spend but if it is worth it i can move like to 1200 max.
 ----------------------------------------UPDATE-------------------------------------------------
i am not using any parts from my old pc, so please include all parts required
thanks in advanced -kevin
http://pcpartpicker.com/user/ViolentBoo/saved/25gT
Get this while it's cheap!
This rig will be better for OCing and contains a much better PSU, it has a 6350 instead of an 8350, but those two extra cores won't help you out that much in gaming yet, and if you really want to make up the difference, you can do so through OCing. I also added extra fans and thermal paste to the build, everyone always seems to forget to add those.
http://pcpartpicker.com/p/1ndaO
Made a list for you, idk about the 3 monitor thing though. everything here is from amazon.com
ASRock 990FX EXTREME3 Socket AM3+/ AMD 990FX/ AMD Quad CrossFireX& nVidia Quad SLI/ SATA3&USB3.0/ A&GbE/ ATX Motherboard $130.25
AMD FX-8350 FX-Series Eight-Core Processor Edition, Black AM3+ FD8350FRHKBOX $194.67
Seagate Barracuda 3 TB HDD SATA 6 Gb/s NCQ 64MB Cache 7200 RPM 3.5-Inch Internal Bare Drive ST3000DM001 $128.98
Corsair Gaming Series 700-Watt ATX/EPS Bronze ATX12V/EPS12V 696 Power Supply GS700 $104.99
XFX AMD Radeon HD 7970 Black Edition 3GB GDDR5 2DVI/HDMI/2Mini DisplayPorts PCI-Express Graphics Cards FX797ATDBC;FX-797A-TDBC $409.99
NZXT Guardian 921 RB ATX Mid Tower Case, Black 921RB-001-BL $69.99
TOTAL: $1038.87
no ram lol?
Okay for 1k i got an fx8350 2tb hd 8gb ram and a hd 7970 http://pcpartpicker.com/p/1ndTe
I dont have a cd drive but if you need one you can get a cheaper psu, evga has a nice 750w for $70. if you dont mind having a slower gpu you could fit a ssd in this build ( http://pcpartpicker.com/p/1ne1e )or if you want to add an ssd later you could get:http://www.amazon.com/dp/B007RHT4K6/?tag=pcpapi-20
Alternative hd 6970 http://www.newegg.com/Product/Product.aspx?Item=N82E16814202035
You already have ram and storage so you can get this http://pcpartpicker.com/p/1neaP
