I want to figure out what the best possible diy pc would probably be like. There would be no price limit on this. Just the best parts on the market for the best possible experience. This is the start for a list of parts (no peripherals or os included). http://pcpartpicker.com/p/3NbSg
As there's no price limit, a big custom loop is a must so that everything runs cool and quiet. Heck, why not a second psu for all that.
Those are ridiculous but since you want the best possible diy, make that AIO to a custom water loop man, and I don't mean just for the cpu and gpu, the mobo and ram should also be water cooled.
Took out the h100i and put a custom part at the bottom saying custom watercooling loop at $500 http://pcpartpicker.com/p/3NcVu
A HAF Stacker could house 9 drives in the top 915R and a super expensive water cooling setup in the bottom one.
https://www.youtube.com/watch?v=QbH6QJo_P4Y
No RAID card for all those drives?
Rampage IV Black Edition is the upgraded version of the Rampage IV Extreme, that would make the motherboard that much more ultimate
http://pcpartpicker.com/part/asus-motherboard-rampageivblackedition
I'm not too into custom watercooling its just too complicated for me. Would be better if someone else updated the list for custom watercooling instead of me
was wondering if i could put liquid nitrogen in the custom loop instead of water
Works differently. You have to have a funnel type of thing and keep pouring in LN2. You also have to know a lot more as you're dealing with sub-zero temperatures. Things such as condensation will occur, and if you don't know how to combat it, you can fry a lot of stuff.
LN2 is very short term cooling as in you need to refill the pot with LN2 every 5 or so minutes to keep it cool, so you could do that but its completely pointless
The tubes would probably become brittle and shatter
unless they were heavily insulated
http://pcpartpicker.com/p/3NfdX Replace the coolers with a $5000 custom loop and then you have the best pc ever
The loop would burst from the pressure long before they would freeze, LN2 at room temperature in a water cooling loop the pressure would be way over 10000 PSI, let that sink in
Why not a few 4k monitors?
I have 6 LG 34UM95 3440x1440 monitors in mine
Where's the pci-e ssd's dude?
Got to have one for for kicks. lose a video card and put in Intel 910 Series Ramsdale 800GB PCI-E Solid State Disk It's not like there is any real plus in having a fourth video card chained in.
