have an unraid setup based upon an AMD threadripper 3970, I have a Catalina and a BigSur VMs. The problem I have is in either VM I would like to run a nested VM, either Parallel or Vmware fusion as I have a few windows programs I would like to run. VMWare fusion (on Catalina, BigSur seems to have a bug with nested VM) tells me it cannot run for lack of VT-X, which I understand is an Intel technology.
Is there a different product (from Parallels, VMWARE fusion)I can use to create / run a nested VM inside a Ryzentosh / Unraid based VM?
I believe I found some answers and they are about using VMWare fusion Version 10 (rather than the latest) which apparently does not have a dependency on VT-X, I will try and report on the results as maybe there is somebody “out there” interested in this setup
hello, no, VmWare fusion does not help and also VirtualBox is not working, I guess running OSX in an unraid VM, prevents me from being able to running any other hypervisor inside OSX (I needed it to run, within OSX, a few windows apps, Outlook one of those, since Outlook for OSX is a piece of rubbish)
