So my Evo 212 fan bit the dust after one month of use....... since I don't have my serial (i threw away the box and ripped off the tag) they're not giving me a replacement.
so what 120mm fans would you guys recommend? I was thinking of getting some cougars but those are case fans and I don't think the direction they blow would work.
any thoughts? try to keep it cheap, I don't want to spend enough that I could have bought a new cooler.
also should I get a 4 pack of normal fans and just strap 2 of em to my heatsink? or buy one PWM fan? the PWM fan moves 60cfm more air (or double the amount of air) at max RPM
While cfm and cost are main attributes to watch along with loudness. You must not forget the factor of build quality and redundancy. Oh and Jetflow may comes with backlight (red or blue).
First I don't care about LED, I like my case to be dark, second Cougar seem pretty good, not to mention CMs fan ONLY LASTED A MONTH so yea. Plus the jetflow is the same price as the cougar I'm looking at, moves 20cfm less air and is 2x as loud.
I must agree on that point with you there - As like you overpay for a brand name in considering CM - I think you should put more research on that cougar fan - try to find something in forums and comments.
No what i mean is its a very shitty blade master, I have the "blade master" ie stock and I have an actaul blade master and the quality is worlds different, the blade master the fan is firmly in place and is very solid, the other one I can jiggle the fan around and is very flimsy
I love Cougar fans. They do really well for heatsinks so might wanna give them a try. They also come in a PWM version as well which you'll want for your CPU cooling application
