is there a big cooling difference between these two? how big is the difference in terms of cooling performance? is the +5-10$ worth it in your opinion?
can i overclock my 760k with it? i will also be getting 4 cougar turbine 120mm fan cases (http://www.newegg.ca/Product/Product.aspx?Item=N82E16835553009) on this cougar solution case http://www.newegg.ca/Product/Product.aspx?Item=N82E16811553003
