Hydrophobic coating
So I was wondering, how bad would it to spray a hydrophobic solution on some of your companents if you are running a water loop.
https://www.youtube.com/watch?v=IPM8OR6W6WE
Also how much more heat would this coating add to the sprayed components...
question is, how conductive is the coating
