Hybrid Graphics
Hey all,
I'm interested in experiences you guys have with hybrid graphics under linux, specifically mux-less AMD cards.
I have a hybrid system in my Dell Inspiron 15R SE and I find myself always struggling with displays. I am currently using catalyst but I also tried out Radeon.
Mostly with catalyst, i'm kind of trusting my settings that say the amd card is doing the rendering.
With Opensource drivers, I had to try out PRIME, but it didn't give the performance I need so I did not dig in any further.
Also I noticed that when not using Catalyst, the CPU temperature gets very high, i'm assuming it's because the integrated graphics is doing most of the work. I have recently noticed the same on Catalyst though but didn't investigate, i'm blaming GNOME for now..
I have also tried passing the AMD card to KVM to try out a bit of virtualization since it's only a rendered and not really a display but I did not have much luck with that either..
Okay so you want iGPU HD4000 is it? with the AMD GPU, I dont believe this is possible is it? I know in windows you can use Lucid, but even that is awful. via KVM possibly this could work but does the GPU its self support passing? And does the board on the dell support VT-d?
Your CPU issue seems to be because the processor is working harder, as said, dont use GNOME though, use KDE or XFCE.
You may need catalyst with KVM for passing if its supported, lspci then check the GPU on internet against this
Post back with anything you find :)
I found that list when I started playing with virtualisation but my GPU was not on it (neither is any mobile GPU really)..
Anyway the way muxless hybrid works is that display is done by the iGPU but the rendering can happen either by the AMD GPU or the intel one that's why I thought maybe i could pass it through. My processor supports VT-d, i checked the board but couldn't find any info about it, the bios option only says virtualisation. I don't understand why I need catalyst for passing, it should be unloaded to my understanding. Have you got your issues with it sorted out though? Maybe when we have a few successful setups we could have a reliable documentation for it once and for all..
And as for DE, GNOME is awesome, except for these few bugs, it increases my workflow and I'm really comfortable using it. KDE just messes up my screens whenever I plugin a second one for some reason and XFCE doesn't give me the satisfaction GNOME does..
GNOME has spyware in it, in the form of Geolocation, so yeah, OSS tends to avoid this :) also Catalyst is needed for the GPU RAM, you can only select a max of 128MB with OSS drivers, Catalyst allows for full Memory capacity, which is why you need it, as far as i gathered from zoltan and my posting.
And basically from what you say its kind of like Lucid but without the fancy GUI with big red buttons lol, and you may not be able to support it then, although your CPU supports VT-d your mobo needs IOMMU to run it correctly, now my feelings towards dell are always negative, I hate dell (Apart from monitors, I love them lol)
For the GPU you need to unbind it and then rebind the card in the VM, which I cant get my head around and zoltan cant make me a script due to hardware differences, so leave iGPU on, so it will technically work as a hybrid in ways, remember binding removes the GPU from host and then adds it to guest.
And no I never sorted mine which is a shame, I am going bare metal on second HDD while I actually fix it, I have also asked on Stack Exchange, fruitless at the moment though, but if we get it sorted we can put the information together and make a guide hopefully
