Hi I'm my new gaming PC, I wanted to try an ssd, but I found them to expensive if they were higher than 32gbs. So I looked into a 1tb hybrid drive from seagate, and a 32 GB ssd for windows, from sandisk. Here is my build, take a look at the drives.
http://pcpartpicker.com/p/1Xll8
So my question is, would this be a good pair for my drives, or would you recommend something else?
Go with a 120gig SSD and get a regular spinning later on, you can get a good quality 120gig SSD for around $100 +- 20 You have $140 in HDD/SSD there so might as well pony up for the 120gig. That would be my recommendation.
I agree with Mutation. Get something like a 120gb HyperX 3k or Samsung 840 EVO. They're priced well.
Later you can just buy something like a 1tb WD Caviar Blue for like $70. If you wait until Black Friday/Cyber Monday, you'll probably be able to pick one up for DIRT cheap. Or you can spend a little extra for 2 or 3tb of storage.
