So I was really wanting to purchase a SFF pre-built that could function as an HTPC system and connect my 3 TerraMaster DAS units.
These are all USB3 devices, not sure if the newest one is 3.1 or not but technically they are all showing about the same transfer rate with spinning rust HDD’s
I just use it to mostly store my backups and some media content.
My idea is to host it on a single machine rather then how it is now, one DAS unit connected onto my Threadripper Workstation and the other on my Gaming Rig.
Also, I use a 2 port KVM swtich box from IO Gear, it is an HDMI + USB model, can I setup some kind of remote access connection onto this HTPC unit or 1 liter unit ?
I have seen many of the VIds that Patrick @ STH puts out with the Tiny/Mini/Micro series and these devices look interesting but would they fit my needs as an HTPC unit or would I need something more powerful.
The display is just a Samsung 42" 4K TV so the media play back could be on that machine or my computer display, which is still an older 1080p as my computer desk is a hutch style and I don’t have room for a larger display in the tight space I have in my room.
Any ideas/tips or tricks are welcome, thanks
