Alright so I have built PCs in the past and know my shit etc but I am clueless to know how a HTPC should be. I am trying to keep this well under 250£ which I believe is around 400$ but I want to be able to access files quickly from either a home server or its own HDD/SSD and keep in mind this is going to be running XBMCBuntu which is obviously XBMC so hint hint I do not care about gaming at all in this build. Obviously this is also a PC not just a HTPC so I can do plenty of other things instead of just 1080p Video Streaming (either from the HDD/SSD or Netflix etc.). So basically all I want you guys to do is to answer my questions.
1) Should I go Intel or AMD (Keep the budget in mind, I honestly don't want to CPU to be over 50£ (75$)
2) Is Intels Pentium Series' Onboard GPU good for 1080p playback?
3) HDD/SSD (Again keep the budget in mind)
4) GPU or no GPU?
5) I'm using Mini ITX for this build so will heat problems be an issue?
6) Is 2GB DDR3 1333mhz alright for this build?
7) Do you think this build is worth the money? (Is it pointless?)
Thanks for your time.
