HTPC Build
i was wondering what cpu would be best for a home theater pc. i wont be doing anything heavy, probably only watching some blu-rays and movie streaming from netflix or other similar services. i would also like to keep it mini-itx so i dont have a giant box under my tv. tired of watching netflix on my phone and refuse to buy a console.
Zotac ID18 and higher will do fine IMHO, its small, all in one, just add RAM and HDD
An AMD A6 should be fine. I have one in my htpc and I'm satisfied with it. If you plan to go mini-itx, Also as a side note if you plan on using wifi, I would recommend getting one with either an optical out or built in wifi as you would be limited to 1pci-e slot in the mini itx form factor. I mean after all you can go wrong with surround sound.
