HP printer connected to my TP-Link network without a password
I just set up a new TP-Link network at home with an ER707-M2 router and EAP607 WAP. I set up the network through Omada including Wi-Fi with a custom password. The last device to connect was a HP Deskjet Plus 4155 printer which required connection through the HP Smart app I have installed on my laptop. When I told it to connect with my local network it did so without asking me the network name or password. I now see the printer as a client on Omada and I never give it permission to do so. I have to assume that the HP Smart app pulled the network information from my laptop and gave it to the printer without my permission. I have some serious security concerns with this.
That is likely what it did and it is a security issue.
This is why I only buy Brother printers. Less shenanigans.
Did it really? I have a HP Envy 5000 series printer, and while the docs only give you the option of using the HP Smart app, I connected it to wifi via the printer’s configuration menu (a bit cumbersome but it works), and print from Linux using a ‘driverless’ driver (one actually positive thing you can thank Apple for). KDE settings even shows the ink levels in the printer info.
