Trying to fix up a laptop as the left button of the track pad is broken. The HP guide I found here: http://www.hp.com/ctg/Manual/c01531211.pdf
This gives part number: Top cover (includes TouchPad and cable) 487300-001
I’m aware this is a pretty old laptop I guess, but it runs well enough. It has a T4200 2GHz, 2GB RAM (DDR2, checking if I can get more working) and a W10 (Home) license, screen is 1280*800 so good enough for some basic work.
My idea is to basically clean it up and see how well I can recover it.
The key issue is the top cover, everything is just in need of a darn good clean. I’m based out of Ecuador and although the keyboard is Spanish (it was purchased in Colombia), the rest looks like any old CQ40.
I looked at a few sites and so far, I’ve not been able to find a place to buy the cover. It appears the part number is not valid on the HP site, even though it is in the PDF I linked (which in itself IS on the HP side).
If you can recommend/link me to a place that sells this part? I don’t mind if it is a second hand part, as long as it is usable and not scratched to …
Thanks in advance for any recommendation you might have, once it is in a good state I can then hand it to someone here who can’t afford a laptop.
