I am choosing between two laptops and I have a tough choice of picking between two laptops. The price is similar with the OMEN being a bit more expensive.
Neither come with an SSD (I will add one anyways since not even I can resist SSD speeds). They both have the same CPU (i7 7700 HQ) and the same, odd RAM config (12 GB, WTF, I can change that anyways if I feel that is an issue once RAM prices drop)
HP Pavilion Power is slimmer and weighs about half as much weight (at 4.4 lbs), I actually felt the build quality on this laptop and it was impressive compared to what I expected. Even the keyboard felt decent. The GPU though isn’t particularly powerful, an RX 550 isn’t very powerful at all, I mean it’s a lot better than Intel HD graphics, but RX 550 is probably going to be surpassed by a top tier Raven Ridge APU. Plus only 2 GB of VRAM. As for I/O, not that impressive but it has the bare minimums I need. Laptop I found is around $850 right now.
HP OMEN that I am looking at is only $1080 for a laptop with an RX 580, which is kind of a beast for a laptop to be quite frank (Yes GTX 1070 and GTX 1080 are bigger beasts in performance but that’s beyond the scope of what I can afford, not to mention probably overkill even). The I/O is a bit nuts, I mean a Thunderbolt 3 USB-C port even. Has room for an optical drive or another storage drive. I have no idea about the build quality but I am guessing it’s even better than the other laptop. Laptop has programmable buttons and a better touchpad. Downside is that the laptop is more like a portable desktop, as cool as that is, it means battery life is most likely absymal and drains hard with that GPU and CPU. It probably runs hot too even with that aggressive ventilation. And the laptop weighs 8.2 lbs and is extra THICC (1.3"), that is kind of big even by my standards.
I will be using my laptop mostly for regular daily tasks with some occasional gaming maybe, but I will have to run a VM with hardware passthrough to do it since I will be maining Linux, the VM part is kind of why I chose an AMD dGPU, otherwise there would be a bunch more laptops to pick from.
